[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/r_paper.c |no clones | 0 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Fri Aug 4 05:17:01 EDT 2006
Hello markus,
ANALYSIS
ps/ps.map/r_paper.c functions
read_paper (Begins at: 28 Ends at: 92)
Complexity:   |      15 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      21 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-04 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
