[GRASS-QA] GRASS QA: glynn | ./grass6/vector/v.surf.idw/main.c |no clones | 1 monsters | 0 warnings
cvs at proxy.soccerlab.polymtl.ca cvs at proxy.soccerlab.polymtl.ca
Tue Aug 8 13:53:10 EDT 2006
Hello glynn,
ANALYSIS
vector/v.surf.idw/main.c functions
main (Begins at: 50 Ends at: 379)
Complexity:   |      27 |    ** | Warning |
CalledNBR:    |      69 |    ** | Warning |
LOC:          |     330 |   *** | MONSTER |
1 metric are OUT OF RANGE!
newpoint (Begins at: 381 Ends at: 412)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      32 |       |      OK |
metrics are OK
calculate_distances (Begins at: 414 Ends at: 468)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      55 |       |      OK |
metrics are OK
calculate_distances_noindex (Begins at: 470 Ends at: 512)
Complexity:   |       4 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-08 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      79 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
