[GRASS-QA] GRASS QA: soeren | ./grass6/raster/r.lake/main.c |no
clones | 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Thu Aug 10 17:35:52 EDT 2006
Hello soeren,
ANALYSIS
raster/r.lake/main.c functions
save_map (Begins at: 41 Ends at: 83)
Complexity: | 9 | | OK |
ParamNBR: | 9 | *** | MONSTER |
CalledNBR: | 14 | | OK |
LOC: | 43 | | OK |
1 metric are OUT OF RANGE!
is_near_water (Begins at: 86 Ends at: 103)
Complexity: | 3 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 18 | | OK |
metrics are OK
load_window_values (Begins at: 106 Ends at: 138)
ParamNBR: | 6 | * | |
LOC: | 33 | | OK |
metrics are OK
main (Begins at: 140 Ends at: 422)
Complexity: | 33 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 111 | *** | MONSTER |
LOC: | 283 | *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-10 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 79 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
