[GRASS-QA] GRASS QA: soeren | ./grass6/lib/gis/parser.c |1 clones (
parser.c )| 1 monsters | 6 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Aug 14 14:11:22 EDT 2006
Hello soeren,
ANALYSIS
lib/gis/parser.c functions
G_disable_interactive (Begins at: 200 Ends at: 216)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_define_flag (Begins at: 219 Ends at: 267)
Complexity: | 3 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 49 | | OK |
metrics are OK
G_define_option (Begins at: 270 Ends at: 340)
LOC: | 71 | | OK |
metrics are OK
G_define_standard_option (Begins at: 343 Ends at: 520)
Complexity: | 22 | * | |
CalledNBR: | 22 | | OK |
LOC: | 178 | * | |
metrics are OK
G_define_module (Begins at: 523 Ends at: 557)
CalledNBR: | 1 | | OK |
LOC: | 35 | | OK |
metrics are OK
G_parser (Begins at: 559 Ends at: 794)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 56 | ** | Warning |
LOC: | 236 | ** | Warning |
at least 3 values are close to an outlier please consider revising code
uses_new_gisprompt (Begins at: 797 Ends at: 842)
Complexity: | 5 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_usage (Begins at: 844 Ends at: 1005)
Complexity: | 31 | ** | Warning |
CalledNBR: | 42 | * | |
LOC: | 162 | * | |
at least 1 values are close to an outlier please consider revising code
print_escaped_for_xml (Begins at: 1007 Ends at: 1023)
Complexity: | 6 | | OK |
LOC: | 17 | | OK |
metrics are OK
G_usage_xml (Begins at: 1025 Ends at: 1223)
Complexity: | 25 | * | |
CalledNBR: | 62 | ** | Warning |
LOC: | 199 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
G_usage_html (Begins at: 1225 Ends at: 1441)
Complexity: | 40 | *** | MONSTER |
CalledNBR: | 71 | ** | Warning |
LOC: | 217 | ** | Warning |
1 metric are OUT OF RANGE!
generate_tcl (Begins at: 1443 Ends at: 1514)
Complexity: | 9 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 72 | | OK |
metrics are OK
G_gui (Begins at: 1517 Ends at: 1539)
CalledNBR: | 8 | | OK |
LOC: | 23 | | OK |
metrics are OK
G_tcltk (Begins at: 1542 Ends at: 1557)
LOC: | 16 | | OK |
metrics are OK
show_options (Begins at: 1559 Ends at: 1588)
Complexity: | 4 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 30 | | OK |
metrics are OK
show (Begins at: 1590 Ends at: 1603)
CalledNBR: | 3 | | OK |
LOC: | 14 | | OK |
metrics are OK
set_flag (Begins at: 1605 Ends at: 1632)
LOC: | 28 | | OK |
metrics are OK
contains (Begins at: 1637 Ends at: 1646)
LOC: | 10 | | OK |
metrics are OK
set_option (Begins at: 1648 Ends at: 1708)
CalledNBR: | 13 | | OK |
LOC: | 61 | | OK |
metrics are OK
check_opts (Begins at: 1710 Ends at: 1747)
LOC: | 38 | | OK |
metrics are OK
check_an_opt (Begins at: 1749 Ends at: 1791)
Complexity: | 10 | | OK |
ParamNBR: | 4 | | OK |
LOC: | 43 | | OK |
metrics are OK
check_int (Begins at: 1793 Ends at: 1859)
Complexity: | 13 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 67 | | OK |
metrics are OK
check_double (Begins at: 1861 Ends at: 1901)
LOC: | 41 | | OK |
metrics are OK
check_string (Begins at: 1903 Ends at: 1930)
Complexity: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
check_required (Begins at: 1932 Ends at: 1955)
LOC: | 24 | | OK |
metrics are OK
split_opts (Begins at: 1957 Ends at: 2020)
LOC: | 64 | | OK |
metrics are OK
check_multiple_opts (Begins at: 2022 Ends at: 2060)
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
check_overwrite (Begins at: 2063 Ends at: 2119)
Complexity: | 11 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 57 | | OK |
metrics are OK
interactive (Begins at: 2121 Ends at: 2149)
LOC: | 29 | | OK |
metrics are OK
interactive_flag (Begins at: 2151 Ends at: 2159)
LOC: | 9 | | OK |
metrics are OK
interactive_option (Begins at: 2161 Ends at: 2251)
Complexity: | 23 | * | |
CalledNBR: | 41 | * | |
LOC: | 91 | | OK |
metrics are OK
split_gisprompt (Begins at: 2253 Ends at: 2283)
LOC: | 31 | | OK |
metrics are OK
gis_prompt (Begins at: 2285 Ends at: 2330)
CalledNBR: | 20 | | OK |
LOC: | 46 | | OK |
metrics are OK
G_recreate_command (Begins at: 2332 Ends at: 2434)
CalledNBR: | 25 | | OK |
LOC: | 103 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
interactive_flag
In lib/gis/parser.c clones of interactive_flag are:
lib/gis/rm_colr.c G_remove_colr
Threshold GRASS6 key metrics values at 2006-08-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
