[GRASS-QA] GRASS QA: soeren | ./grass6/vector/v.out.vtk/head.c |no clones | 0 monsters | 0 warnings
Mon Aug 14 16:54:20 EDT 2006
Hello soeren,
ANALYSIS
vector/v.out.vtk/head.c functions
write_vtk_head (Begins at: 25 Ends at: 33)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-14 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
