[GRASS-QA] GRASS QA: glynn |
./grass6/raster/r.series/c_percentile.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Mon Aug 14 23:24:31 EDT 2006
Hello glynn,
ANALYSIS
raster/r.series/c_percentile.c functions
percentile (Begins at: 5 Ends at: 25)
Complexity: | 2 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 21 | | OK |
metrics are OK
c_quart1 (Begins at: 27 Ends at: 30)
Complexity: | 1 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
c_quart3 (Begins at: 32 Ends at: 35)
LOC: | 4 | | OK |
metrics are OK
c_perc90 (Begins at: 37 Ends at: 40)
LOC: | 4 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-14 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
