[GRASS-QA] GRASS QA: markus | ./grass6/lib/gis/color_str.c |no clones | 0 monsters | 0 warnings
Tue Aug 15 08:47:51 EDT 2006
Hello markus,
ANALYSIS
lib/gis/color_str.c functions
G_str_to_color (Begins at: 54 Ends at: 91)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-15 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
