[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.out.dxf/main.c |no clones | 0 monsters | 0 warnings
Wed Aug 16 19:14:22 EDT 2006
Hello markus,
ANALYSIS
vector/v.out.dxf/main.c functions
main (Begins at: 34 Ends at: 89)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      26 |       |      OK |
LOC:          |      56 |       |      OK |
metrics are OK
do_limits (Begins at: 91 Ends at: 108)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      18 |       |      OK |
metrics are OK
make_layername (Begins at: 110 Ends at: 130)
Complexity:   |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      21 |       |      OK |
metrics are OK
add_plines (Begins at: 132 Ends at: 189)
Complexity:   |       6 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      58 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-16 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
