[GRASS-QA] GRASS QA: glynn | ./grass6/raster/r.neighbors/main.c |no
clones | 0 monsters | 2 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 07:19:43 EDT 2006
Hello glynn,
ANALYSIS
raster/r.neighbors/main.c functions
main (Begins at: 18 Ends at: 255)
Complexity: | 20 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 79 | *** | MONSTER |
LOC: | 238 | ** | Warning |
at least 2 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
