[GRASS-QA] GRASS QA: glynn | ./grass6/ps/ps.map/do_geogrid.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 07:27:43 EDT 2006
Hello glynn,
ANALYSIS
ps/ps.map/do_geogrid.c functions
do_geogrid (Begins at: 34 Ends at: 132)
Complexity:   |      11 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      28 |       |      OK |
LOC:          |      99 |       |      OK |
metrics are OK
do_geogrid_numbers (Begins at: 138 Ends at: 252)
Complexity:   |      13 |       |      OK |
CalledNBR:    |      34 |     * |         |
LOC:          |     115 |     * |         |
metrics are OK
init_proj (Begins at: 258 Ends at: 277)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
get_ll_bounds (Begins at: 283 Ends at: 361)
ParamNBR:     |       4 |       |      OK |
LOC:          |      79 |       |      OK |
metrics are OK
check_coords (Begins at: 369 Ends at: 427)
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      10 |       |      OK |
LOC:          |      59 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
