[GRASS-QA] GRASS QA: markus | ./grass6/db/base/describe.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 09:20:38 EDT 2006
Hello markus,
ANALYSIS
db/base/describe.c functions
main (Begins at: 22 Ends at: 68)
Complexity: | 5 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 26 | | OK |
LOC: | 47 | | OK |
metrics are OK
parse_command_line (Begins at: 71 Ends at: 121)
Complexity: | 4 | | OK |
CalledNBR: | 17 | | OK |
LOC: | 51 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
