[GRASS-QA] GRASS QA: markus | ./grass6/misc/m.cogo/main.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 09:20:41 EDT 2006
Hello markus,
ANALYSIS
misc/m.cogo/main.c functions
print_coordinates (Begins at: 55 Ends at: 61)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
print_cogo (Begins at: 65 Ends at: 75)
LOC:          |      11 |       |      OK |
metrics are OK
next_line (Begins at: 79 Ends at: 87)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
parse_forward (Begins at: 91 Ends at: 151)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      61 |       |      OK |
metrics are OK
parse_reverse (Begins at: 155 Ends at: 224)
Complexity:   |       8 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      70 |       |      OK |
metrics are OK
main (Begins at: 228 Ends at: 368)
Complexity:   |      17 |     * |         |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      25 |       |      OK |
LOC:          |     141 |     * |         |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
