[GRASS-QA] GRASS QA: markus | ./grass6/display/d.rast/main.c |4
clones ( main.c )| 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 09:20:39 EDT 2006
Hello markus,
ANALYSIS
display/d.rast/main.c functions
main (Begins at: 12 Ends at: 119)
Complexity: | 9 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 38 | * | |
LOC: | 108 | | OK |
metrics are OK
parse_catlist (Begins at: 121 Ends at: 154)
Complexity: | 6 | | OK |
CalledNBR: | 10 | | OK |
LOC: | 34 | | OK |
metrics are OK
parse_vallist (Begins at: 156 Ends at: 189)
LOC: | 34 | | OK |
metrics are OK
parse_mask_rule (Begins at: 192 Ends at: 222)
ParamNBR: | 3 | | OK |
CalledNBR: | 11 | | OK |
LOC: | 31 | | OK |
metrics are OK
parse_d_mask_rule (Begins at: 225 Ends at: 255)
LOC: | 31 | | OK |
metrics are OK
Clone analysis:
This file has 4 potentially cloned functions:
parse_d_mask_rule parse_mask_rule parse_vallist parse_catlist
In display/d.rast/main.c clones of parse_catlist are:
raster/r.null/null.c parse_vallist
display/d.rast/main.c parse_vallist
In display/d.rast/main.c clones of parse_vallist are:
display/d.rast/main.c parse_catlist
In display/d.rast/main.c clones of parse_mask_rule are:
display/d.rast/main.c parse_d_mask_rule
In display/d.rast/main.c clones of parse_d_mask_rule are:
display/d.rast/main.c parse_mask_rule
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
