[GRASS-QA] GRASS QA: markus | ./grass6/display/d.save/main.c |no
clones | 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:32 EDT 2006
Hello markus,
ANALYSIS
display/d.save/main.c functions
main (Begins at: 50 Ends at: 375)
Complexity: | 38 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 78 | ** | Warning |
LOC: | 326 | *** | MONSTER |
2 metric are OUT OF RANGE!
in_frame_list (Begins at: 379 Ends at: 387)
Complexity: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 9 | | OK |
metrics are OK
init_globals (Begins at: 390 Ends at: 403)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 14 | | OK |
metrics are OK
which_item (Begins at: 429 Ends at: 437)
Complexity: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
set_item (Begins at: 441 Ends at: 495)
Complexity: | 16 | * | |
CalledNBR: | 21 | | OK |
LOC: | 55 | | OK |
metrics are OK
process_list (Begins at: 499 Ends at: 530)
Complexity: | 8 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 32 | | OK |
metrics are OK
process_items (Begins at: 535 Ends at: 557)
CalledNBR: | 6 | | OK |
LOC: | 23 | | OK |
metrics are OK
process_pad (Begins at: 561 Ends at: 574)
CalledNBR: | 4 | | OK |
LOC: | 14 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
