[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.bin/main.c |1 clones ( main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c )| 3 monsters | 0 warnings
Sat Aug 19 11:21:38 EDT 2006
Hello markus,
ANALYSIS
raster/r.in.bin/main.c functions
SwabShort (Begins at: 26 Ends at: 32)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
SwabLong (Begins at: 35 Ends at: 42)
LOC:          |       8 |       |      OK |
metrics are OK
SwabFloat (Begins at: 45 Ends at: 48)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
SwabDouble (Begins at: 51 Ends at: 60)
LOC:          |      10 |       |      OK |
metrics are OK
main (Begins at: 62 Ends at: 525)
Complexity:   |      70 |   *** | MONSTER |
CalledNBR:    |     150 |   *** | MONSTER |
LOC:          |     464 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
  SwabLong
In raster/r.in.bin/main.c clones of  SwabLong are:
	raster/r.out.bin/tif_swab.c  TIFFSwabLong
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
