[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/v.lidar.edgedetection/main.c |no clones
| 2 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:45 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.lidar.edgedetection/main.c functions
main (Begins at: 38 Ends at: 352)
Complexity: | 21 | * | |
ParamNBR: | 2 | | OK |
CalledNBR: | 135 | *** | MONSTER |
LOC: | 315 | *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
