[GRASS-QA] GRASS QA: markus | ./grass6/paint/p.out.vrml/main.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 11:21:35 EDT 2006
Hello markus,
ANALYSIS
paint/p.out.vrml/main.c functions
main (Begins at: 13 Ends at: 177)
Complexity:   |      16 |     * |         |
CalledNBR:    |      50 |     * |         |
LOC:          |     165 |     * |         |
metrics are OK
init_coordcnv (Begins at: 203 Ends at: 226)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
do_coordcnv (Begins at: 229 Ends at: 253)
Complexity:   |       9 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      25 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
