[GRASS-QA] GRASS QA: markus |
./grass6/display/d.linegraph/linegraph.c |no clones | 2
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:31 EDT 2006
Hello markus,
ANALYSIS
display/d.linegraph/linegraph.c functions
main (Begins at: 36 Ends at: 589)
Complexity: | 34 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 123 | *** | MONSTER |
LOC: | 554 | *** | MONSTER |
2 metric are OUT OF RANGE!
rem (Begins at: 591 Ends at: 595)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 5 | | OK |
metrics are OK
death (Begins at: 599 Ends at: 608)
ParamNBR: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 10 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
