[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.cats/main.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 11:21:36 EDT 2006
Hello markus,
ANALYSIS
raster/r.cats/main.c functions
main (Begins at: 12 Ends at: 132)
Complexity:   |      16 |     * |         |
CalledNBR:    |      45 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
print_label (Begins at: 135 Ends at: 143)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
print_d_label (Begins at: 146 Ends at: 158)
CalledNBR:    |       5 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
scan_cats (Begins at: 161 Ends at: 175)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      15 |       |      OK |
metrics are OK
scan_vals (Begins at: 178 Ends at: 185)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
