Hello markus,
ANALYSIS
vector/v.build.polylines/main.c functions
main (Begins at: 80 Ends at: 226)
Complexity: | 10 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 44 | * | |
LOC: | 147 | * | |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
