[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/r3.to.rast/main.c |1 clones ( main.c main.c main.c parser.c main.c main.c main.c main.c main.c )| 0 monsters | 1 warnings
Sat Aug 19 11:21:36 EDT 2006
Hello markus,
ANALYSIS
raster3d/r3.to.rast/main.c functions
fatalError (Begins at: 49 Ends at: 67)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
setParams (Begins at: 73 Ends at: 100)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       0 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
G3dToRaster (Begins at: 107 Ends at: 177)
Complexity:   |      12 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      71 |       |      OK |
metrics are OK
main (Begins at: 183 Ends at: 343)
Complexity:   |      21 |     * |         |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     161 |     * |         |
at least 1 values are close to an outlier please consider revising code
open_output_map (Begins at: 350 Ends at: 359)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
close_output_map (Begins at: 364 Ends at: 368)
ParamNBR:     |       1 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  setParams
In raster3d/r3.to.rast/main.c clones of  setParams are:
	raster3d/r3.cross.rast/main.c  SetParameter
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
