[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.in.gdal/main.c |no clones | 5 monsters | 0 warnings
Sat Aug 19 11:21:38 EDT 2006
Hello markus,
ANALYSIS
raster/r.in.gdal/main.c functions
main (Begins at: 40 Ends at: 548)
Complexity:   |      45 |   *** | MONSTER |
CalledNBR:    |     149 |   *** | MONSTER |
LOC:          |     509 |   *** | MONSTER |
3 metric are OUT OF RANGE!
SetupReprojector (Begins at: 554 Ends at: 607)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |      17 |       |      OK |
LOC:          |      54 |       |      OK |
metrics are OK
ImportBand (Begins at: 614 Ends at: 919)
Complexity:   |      34 |    ** | Warning |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      84 |   *** | MONSTER |
LOC:          |     306 |   *** | MONSTER |
2 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
