[GRASS-QA] GRASS QA: markus |
./grass6/raster3d/r3.cross.rast/main.c |1 clones ( main.c
main.c main.c parser.c main.c )| 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:35 EDT 2006
Hello markus,
ANALYSIS
raster3d/r3.cross.rast/main.c functions
FatalError (Begins at: 48 Ends at: 68)
Complexity: | 5 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 21 | | OK |
metrics are OK
SetParameter (Begins at: 74 Ends at: 101)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 28 | | OK |
metrics are OK
G3dCrossRaster (Begins at: 108 Ends at: 237)
Complexity: | 23 | * | |
CalledNBR: | 30 | | OK |
LOC: | 130 | * | |
metrics are OK
main (Begins at: 243 Ends at: 393)
ParamNBR: | 2 | | OK |
CalledNBR: | 62 | ** | Warning |
LOC: | 151 | * | |
at least 1 values are close to an outlier please consider revising code
CloseOutputMap (Begins at: 399 Ends at: 403)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
SetParameter
In raster3d/r3.cross.rast/main.c clones of SetParameter are:
raster3d/r3.to.rast/main.c setParams
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
