[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.hull/main.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 11:21:47 EDT 2006
Hello markus,
ANALYSIS
vector/v.hull/main.c functions
rightTurn (Begins at: 37 Ends at: 44)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       8 |       |      OK |
metrics are OK
cmpPoints (Begins at: 47 Ends at: 57)
Complexity:   |       3 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
convexHull (Begins at: 60 Ends at: 122)
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      63 |       |      OK |
metrics are OK
loadSiteCoordinates (Begins at: 127 Ends at: 153)
Complexity:   |       6 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
outputHull (Begins at: 161 Ends at: 203)
CalledNBR:    |      13 |       |      OK |
LOC:          |      43 |       |      OK |
metrics are OK
main (Begins at: 207 Ends at: 287)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      24 |       |      OK |
LOC:          |      81 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
