[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.surf.area/main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:43 EDT 2006
Hello markus,
ANALYSIS
raster/r.surf.area/main.c functions
main (Begins at: 71 Ends at: 181)
Complexity: | 6 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 38 | * | |
LOC: | 111 | * | |
metrics are OK
add_row_area (Begins at: 186 Ends at: 268)
Complexity: | 2 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 12 | | OK |
LOC: | 83 | | OK |
metrics are OK
add_null_area (Begins at: 273 Ends at: 282)
ParamNBR: | 3 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 10 | | OK |
metrics are OK
v3cross (Begins at: 287 Ends at: 293)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 7 | | OK |
metrics are OK
v3mag (Begins at: 298 Ends at: 302)
LOC: | 5 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
