[GRASS-QA] GRASS QA: markus | ./grass6/raster3d/base/r3.mask.main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:21:35 EDT 2006
Hello markus,
ANALYSIS
raster3d/base/r3.mask.main.c functions
setParams (Begins at: 36 Ends at: 53)
Complexity: | 1 | | OK |
ParamNBR: | 0 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 18 | | OK |
metrics are OK
getParams (Begins at: 57 Ends at: 61)
ParamNBR: | 2 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
makeMask (Begins at: 67 Ends at: 140)
Complexity: | 11 | | OK |
CalledNBR: | 43 | * | |
LOC: | 74 | | OK |
metrics are OK
main (Begins at: 144 Ends at: 169)
Complexity: | 3 | | OK |
CalledNBR: | 13 | | OK |
LOC: | 26 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
