[GRASS-QA] GRASS QA: markus | ./grass6/display/d.mon/cmd/main.c |1 clones ( main.c )| 0 monsters | 0 warnings
Sat Aug 19 11:21:32 EDT 2006
Hello markus,
ANALYSIS
display/d.mon/cmd/main.c functions
main (Begins at: 16 Ends at: 136)
Complexity:   |      16 |     * |         |
CalledNBR:    |      43 |     * |         |
LOC:          |     121 |     * |         |
metrics are OK
run (Begins at: 138 Ends at: 144)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  run
In display/d.mon/cmd/main.c clones of  run are:
	raster/r.what/die.c  die
	raster/r.digit/create_map.c  create_map
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
