[GRASS-QA] GRASS QA: martinl | ./grass6/general/g.region/cmd/printwindow.c |no clones | 3 monsters | 0 warnings
Sat Aug 19 11:38:17 EDT 2006
Hello martinl,
ANALYSIS
general/g.region/cmd/printwindow.c functions
print_window (Begins at: 9 Ends at: 466)
Complexity:   |      55 |   *** | MONSTER |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |     186 |   *** | MONSTER |
LOC:          |     458 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
