[GRASS-QA] GRASS QA: markus | ./grass6/ps/ps.map/do_geogrid.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:38:16 EDT 2006
Hello markus,
ANALYSIS
ps/ps.map/do_geogrid.c functions
do_geogrid (Begins at: 34 Ends at: 132)
Complexity: | 11 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 28 | | OK |
LOC: | 99 | | OK |
metrics are OK
do_geogrid_numbers (Begins at: 138 Ends at: 252)
Complexity: | 13 | | OK |
CalledNBR: | 34 | * | |
LOC: | 115 | * | |
metrics are OK
init_proj (Begins at: 258 Ends at: 277)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 8 | | OK |
LOC: | 20 | | OK |
metrics are OK
get_ll_bounds (Begins at: 283 Ends at: 361)
ParamNBR: | 4 | | OK |
LOC: | 79 | | OK |
metrics are OK
check_coords (Begins at: 369 Ends at: 427)
ParamNBR: | 5 | * | |
CalledNBR: | 10 | | OK |
LOC: | 59 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
