[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/TcholBand.c |no clones | 0 monsters | 0 warnings
Sat Aug 19 11:38:16 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/TcholBand.c functions
tcholDec (Begins at: 11 Ends at: 30)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       3 |       |      OK |
LOC:          |      20 |       |      OK |
metrics are OK
tcholSolve (Begins at: 35 Ends at: 68)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       5 |     * |         |
LOC:          |      34 |       |      OK |
metrics are OK
tcholSolve2 (Begins at: 75 Ends at: 98)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
tcholInv (Begins at: 103 Ends at: 141)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
tcholSolveInv (Begins at: 146 Ends at: 202)
LOC:          |      57 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-19 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
