[GRASS-QA] GRASS QA: martinl |
./grass6/general/g.region/cmd/adjust.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 11:38:17 EDT 2006
Hello martinl,
ANALYSIS
general/g.region/cmd/adjust.c functions
adjust_window (Begins at: 4 Ends at: 16)
Complexity: | 2 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 13 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
