[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/lidarlib/TcholBand.c |no clones | 0
monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sat Aug 19 12:25:03 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/TcholBand.c functions
tcholDec (Begins at: 11 Ends at: 30)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 20 | | OK |
metrics are OK
tcholSolve (Begins at: 35 Ends at: 68)
Complexity: | 3 | | OK |
ParamNBR: | 5 | * | |
LOC: | 34 | | OK |
metrics are OK
tcholSolve2 (Begins at: 75 Ends at: 98)
ParamNBR: | 6 | * | |
CalledNBR: | 0 | | OK |
LOC: | 24 | | OK |
metrics are OK
tcholInv (Begins at: 103 Ends at: 141)
Complexity: | 2 | | OK |
CalledNBR: | 5 | | OK |
LOC: | 39 | | OK |
metrics are OK
tcholSolveInv (Begins at: 146 Ends at: 202)
LOC: | 57 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-19 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
