[GRASS-QA] GRASS QA: martinl | ./grass6/lib/gis/adj_cellhd.c |no
clones | 0 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Sun Aug 20 10:47:01 EDT 2006
Hello martinl,
ANALYSIS
lib/gis/adj_cellhd.c functions
G_adjust_Cell_head (Begins at: 64 Ends at: 201)
Complexity: | 21 | * | |
ParamNBR: | 3 | | OK |
CalledNBR: | 15 | | OK |
LOC: | 138 | * | |
metrics are OK
G_adjust_Cell_head3 (Begins at: 203 Ends at: 357)
Complexity: | 33 | ** | Warning |
ParamNBR: | 4 | | OK |
CalledNBR: | 22 | | OK |
LOC: | 155 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-20 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
