[GRASS-QA] GRASS QA: martinl | ./grass6/general/g.region/cmd/main.c |1 clones ( main.c )| 3 monsters | 0 warnings
Sun Aug 20 10:58:10 EDT 2006
Hello martinl,
ANALYSIS
general/g.region/cmd/main.c functions
main (Begins at: 28 Ends at: 767)
Complexity:   |     104 |   *** | MONSTER |
CalledNBR:    |     221 |   *** | MONSTER |
LOC:          |     740 |   *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 769 Ends at: 775)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
nsew (Begins at: 777 Ends at: 783)
Complexity:   |       4 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
llinfo (Begins at: 785 Ends at: 793)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       3 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  nsew
In general/g.region/cmd/main.c clones of  nsew are:
	raster/r.region/main.c  nsew
Threshold GRASS6 key metrics values at 2006-08-20 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
