[GRASS-QA] GRASS QA: markus |
./grass6/vector/lidar/v.lidar.correction/correction.c |no
clones | 1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Tue Aug 22 16:15:53 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.lidar.correction/correction.c functions
P_Sparse_Correction (Begins at: 11 Ends at: 157)
Complexity: | 25 | * | |
ParamNBR: | 13 | *** | MONSTER |
CalledNBR: | 62 | ** | Warning |
LOC: | 147 | * | |
1 metric are OUT OF RANGE!
correction (Begins at: 160 Ends at: 178)
Complexity: | 5 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 19 | | OK |
metrics are OK
Select_Correction (Begins at: 180 Ends at: 209)
Complexity: | 4 | | OK |
CalledNBR: | 12 | | OK |
LOC: | 30 | | OK |
metrics are OK
Insert_Correction (Begins at: 211 Ends at: 223)
Complexity: | 1 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 13 | | OK |
metrics are OK
UpDate_Correction (Begins at: 225 Ends at: 235)
CalledNBR: | 4 | | OK |
LOC: | 11 | | OK |
metrics are OK
P_Read_Vector_Correction (Begins at: 238 Ends at: 302)
Complexity: | 6 | | OK |
ParamNBR: | 5 | * | |
CalledNBR: | 11 | | OK |
LOC: | 65 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-22 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
