[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/v.lidar.correction/correction.c |no clones | 1 monsters | 0 warnings
Tue Aug 22 17:39:37 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/v.lidar.correction/correction.c functions
P_Sparse_Correction (Begins at: 11 Ends at: 157)
Complexity:   |      25 |     * |         |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      62 |    ** | Warning |
LOC:          |     147 |     * |         |
1 metric are OUT OF RANGE!
correction (Begins at: 160 Ends at: 178)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      19 |       |      OK |
metrics are OK
Select_Correction (Begins at: 180 Ends at: 209)
Complexity:   |       4 |       |      OK |
CalledNBR:    |      12 |       |      OK |
LOC:          |      30 |       |      OK |
metrics are OK
Insert_Correction (Begins at: 211 Ends at: 223)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       6 |       |      OK |
LOC:          |      13 |       |      OK |
metrics are OK
UpDate_Correction (Begins at: 225 Ends at: 235)
CalledNBR:    |       4 |       |      OK |
LOC:          |      11 |       |      OK |
metrics are OK
P_Read_Vector_Correction (Begins at: 238 Ends at: 302)
Complexity:   |       6 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |      65 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
