[GRASS-QA] GRASS QA: markus | ./grass6/vector/lidar/lidarlib/InterpSpline.c |2 clones ( InterpSpline.c )| 6 monsters | 0 warnings
Tue Aug 22 17:39:37 EDT 2006
Hello markus,
ANALYSIS
vector/lidar/lidarlib/InterpSpline.c functions
node_x (Begins at: 12 Ends at: 18)
Complexity:   |       1 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |       0 |       |      OK |
LOC:          |       7 |       |      OK |
metrics are OK
node_y (Begins at: 23 Ends at: 29)
LOC:          |       7 |       |      OK |
metrics are OK
order (Begins at: 34 Ends at: 37)
ParamNBR:     |       3 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_3 (Begins at: 42 Ends at: 45)
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_4 (Begins at: 47 Ends at: 50)
CalledNBR:    |       1 |       |      OK |
LOC:          |       4 |       |      OK |
metrics are OK
phi_33 (Begins at: 52 Ends at: 55)
LOC:          |       4 |       |      OK |
metrics are OK
phi_34 (Begins at: 57 Ends at: 60)
LOC:          |       4 |       |      OK |
metrics are OK
phi_43 (Begins at: 62 Ends at: 65)
LOC:          |       4 |       |      OK |
metrics are OK
phi_44 (Begins at: 67 Ends at: 70)
LOC:          |       4 |       |      OK |
metrics are OK
phi (Begins at: 72 Ends at: 75)
LOC:          |       4 |       |      OK |
metrics are OK
normalDefBicubic (Begins at: 80 Ends at: 156)
Complexity:   |       5 |       |      OK |
ParamNBR:     |      13 |   *** | MONSTER |
CalledNBR:    |      22 |       |      OK |
LOC:          |      77 |       |      OK |
1 metric are OUT OF RANGE!
nCorrectLapl (Begins at: 162 Ends at: 235)
ParamNBR:     |       6 |     * |         |
CalledNBR:    |       3 |       |      OK |
LOC:          |      74 |       |      OK |
metrics are OK
normalDefBilin (Begins at: 240 Ends at: 336)
CalledNBR:    |      10 |       |      OK |
LOC:          |      97 |       |      OK |
nCorrectGrad (Begins at: 338 Ends at: 366)
Complexity:   |       3 |       |      OK |
LOC:          |      29 |       |      OK |
metrics are OK
obsEstimateBicubic (Begins at: 371 Ends at: 425)
ParamNBR:     |      10 |   *** | MONSTER |
CalledNBR:    |      19 |       |      OK |
LOC:          |      55 |       |      OK |
dataInterpolateBicubic (Begins at: 431 Ends at: 482)
ParamNBR:     |       9 |   *** | MONSTER |
LOC:          |      52 |       |      OK |
obsEstimateBilin (Begins at: 488 Ends at: 527)
CalledNBR:    |       7 |       |      OK |
LOC:          |      40 |       |      OK |
dataInterpolateBilin (Begins at: 533 Ends at: 569)
LOC:          |      37 |       |      OK |
Clone analysis:
This file has 2 potentially cloned functions:
  node_y  node_x
In vector/lidar/lidarlib/InterpSpline.c clones of  node_x are:
	vector/lidar/lidarlib/InterpSpline.c  node_y
In vector/lidar/lidarlib/InterpSpline.c clones of  node_y are:
	vector/lidar/lidarlib/InterpSpline.c  node_x
Threshold GRASS6 key metrics values at 2006-08-22 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
