[GRASS-QA] GRASS QA: markus | ./grass6/display/d.nviz/main.c |1
clones ( main.c main.c )| 2 monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:07 EDT 2006
Hello markus,
ANALYSIS
display/d.nviz/main.c functions
main (Begins at: 43 Ends at: 396)
Complexity: | 26 | ** | Warning |
ParamNBR: | 2 | | OK |
CalledNBR: | 157 | *** | MONSTER |
LOC: | 354 | *** | MONSTER |
2 metric are OUT OF RANGE!
do_profile (Begins at: 403 Ends at: 472)
Complexity: | 10 | | OK |
ParamNBR: | 7 | ** | Warning |
CalledNBR: | 29 | | OK |
LOC: | 70 | | OK |
at least 1 values are close to an outlier please consider revising code
move (Begins at: 475 Ends at: 480)
Complexity: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 6 | | OK |
metrics are OK
cont (Begins at: 482 Ends at: 503)
Complexity: | 5 | | OK |
LOC: | 22 | | OK |
metrics are OK
read_rast (Begins at: 510 Ends at: 613)
Complexity: | 15 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 24 | | OK |
LOC: | 104 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
cont
In display/d.nviz/main.c clones of cont are:
raster/r.profile/main.c cont
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
