[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.region/main.c |1
clones ( main.c main.c main.c main.c main.c main.c main.c
main.c parser.c main.c main.c main.c main.c main.c main.c
main.c main.c null.c main.c )| 3 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:19 EDT 2006
Hello markus,
ANALYSIS
raster/r.region/main.c functions
main (Begins at: 25 Ends at: 375)
Complexity: | 58 | *** | MONSTER |
ParamNBR: | 2 | | OK |
CalledNBR: | 118 | *** | MONSTER |
LOC: | 351 | *** | MONSTER |
3 metric are OUT OF RANGE!
die (Begins at: 377 Ends at: 380)
Complexity: | 1 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 4 | | OK |
metrics are OK
nsew (Begins at: 382 Ends at: 388)
Complexity: | 4 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 7 | | OK |
metrics are OK
llinfo (Begins at: 390 Ends at: 398)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 2 | | OK |
LOC: | 9 | | OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
nsew
In raster/r.region/main.c clones of nsew are:
general/g.region/cmd/main.c nsew
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
