[GRASS-QA] GRASS QA: markus | ./grass6/lib/ogsf/gvld.c |no clones |
1 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:13 EDT 2006
Hello markus,
ANALYSIS
lib/ogsf/gvld.c functions
gvld_vol (Begins at: 17 Ends at: 42)
Complexity: | 5 | | OK |
ParamNBR: | 1 | | OK |
CalledNBR: | 4 | | OK |
LOC: | 26 | | OK |
metrics are OK
gvld_wire_vol (Begins at: 45 Ends at: 62)
Complexity: | 3 | | OK |
CalledNBR: | 3 | | OK |
LOC: | 18 | | OK |
metrics are OK
gvld_isosurf (Begins at: 65 Ends at: 362)
Complexity: | 23 | * | |
CalledNBR: | 52 | * | |
LOC: | 298 | *** | MONSTER |
1 metric are OUT OF RANGE!
gvld_wire_isosurf (Begins at: 365 Ends at: 376)
Complexity: | 1 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 12 | | OK |
metrics are OK
gvld_slices (Begins at: 378 Ends at: 429)
CalledNBR: | 17 | | OK |
LOC: | 52 | | OK |
metrics are OK
gvld_slice (Begins at: 433 Ends at: 572)
Complexity: | 8 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 9 | | OK |
LOC: | 140 | * | |
metrics are OK
gvld_wire_slices (Begins at: 576 Ends at: 660)
CalledNBR: | 16 | | OK |
LOC: | 85 | | OK |
metrics are OK
gvld_wind3_box (Begins at: 664 Ends at: 750)
CalledNBR: | 38 | * | |
LOC: | 87 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
