[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.sun/main.c |no clones | 4 monsters | 3 warnings
Wed Aug 23 07:40:20 EDT 2006
Hello markus,
ANALYSIS
raster/r.sun/main.c functions
main (Begins at: 132 Ends at: 451)
Complexity:   |      24 |     * |         |
CalledNBR:    |      95 |   *** | MONSTER |
LOC:          |     320 |   *** | MONSTER |
2 metric are OUT OF RANGE!
INPUT (Begins at: 454 Ends at: 673)
Complexity:   |      45 |   *** | MONSTER |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      81 |   *** | MONSTER |
LOC:          |     220 |    ** | Warning |
OUTGR (Begins at: 675 Ends at: 805)
Complexity:   |      29 |    ** | Warning |
CalledNBR:    |      50 |     * |         |
LOC:          |     131 |     * |         |
at least 1 values are close to an outlier please consider revising code
com_par_const (Begins at: 808 Ends at: 845)
Complexity:   |       6 |       |      OK |
CalledNBR:    |       7 |       |      OK |
LOC:          |      38 |       |      OK |
metrics are OK
com_par (Begins at: 848 Ends at: 919)
Complexity:   |       8 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      72 |       |      OK |
metrics are OK
lumcline2 (Begins at: 923 Ends at: 961)
Complexity:   |       7 |       |      OK |
CalledNBR:    |       2 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
joules2 (Begins at: 963 Ends at: 1093)
Complexity:   |      22 |     * |         |
CalledNBR:    |      11 |       |      OK |
LOC:          |     131 |     * |         |
metrics are OK
new_point (Begins at: 1098 Ends at: 1107)
Complexity:   |       2 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
where_is_point (Begins at: 1109 Ends at: 1134)
LOC:          |      26 |       |      OK |
metrics are OK
cube (Begins at: 1136 Ends at: 1141)
LOC:          |       6 |       |      OK |
metrics are OK
searching (Begins at: 1143 Ends at: 1169)
CalledNBR:    |       3 |       |      OK |
LOC:          |      27 |       |      OK |
metrics are OK
calculate (Begins at: 1175 Ends at: 1412)
CalledNBR:    |      53 |     * |         |
LOC:          |     238 |    ** | Warning |
at least 2 values are close to an outlier please consider revising code
com_sol_const (Begins at: 1414 Ends at: 1423)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       1 |       |      OK |
LOC:          |      10 |       |      OK |
metrics are OK
com_declin (Begins at: 1426 Ends at: 1436)
LOC:          |      11 |       |      OK |
metrics are OK
brad (Begins at: 1438 Ends at: 1465)
Complexity:   |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
drad (Begins at: 1467 Ends at: 1521)
LOC:          |      55 |       |      OK |
metrics are OK
test (Begins at: 1523 Ends at: 1537)
LOC:          |      15 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
