[GRASS-QA] GRASS QA: markus | ./grass6/raster/r.what/main.c |no clones | 2 monsters | 0 warnings
Wed Aug 23 07:40:22 EDT 2006
Hello markus,
ANALYSIS
raster/r.what/main.c functions
main (Begins at: 27 Ends at: 373)
Complexity:   |      43 |   *** | MONSTER |
CalledNBR:    |      77 |    ** | Warning |
LOC:          |     347 |   *** | MONSTER |
2 metric are OUT OF RANGE!
oops (Begins at: 376 Ends at: 392)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       3 |       |      OK |
CalledNBR:    |       4 |       |      OK |
LOC:          |      17 |       |      OK |
metrics are OK
by_row (Begins at: 396 Ends at: 400)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       0 |       |      OK |
LOC:          |       5 |       |      OK |
metrics are OK
by_point (Begins at: 404 Ends at: 408)
LOC:          |       5 |       |      OK |
metrics are OK
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
