[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.buffer/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c main.c null.c main.c main.c main.c main.c main.c )| 3 monsters | 0 warnings
Wed Aug 23 07:40:23 EDT 2006
Hello markus,
ANALYSIS
vector/v.buffer/main.c functions
input_distance (Begins at: 35 Ends at: 121)
Complexity:   |      14 |       |      OK |
ParamNBR:     |       5 |     * |         |
CalledNBR:    |      16 |       |      OK |
LOC:          |      87 |       |      OK |
metrics are OK
area_in_buffer (Begins at: 128 Ends at: 207)
Complexity:   |       8 |       |      OK |
ParamNBR:     |       6 |     * |         |
CalledNBR:    |      15 |       |      OK |
LOC:          |      80 |       |      OK |
metrics are OK
stop (Begins at: 209 Ends at: 217)
Complexity:   |       1 |       |      OK |
CalledNBR:    |       5 |       |      OK |
LOC:          |       9 |       |      OK |
metrics are OK
main (Begins at: 220 Ends at: 709)
Complexity:   |      56 |   *** | MONSTER |
CalledNBR:    |     180 |   *** | MONSTER |
LOC:          |     490 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
This file has 1 potentially cloned functions:
  stop
In vector/v.buffer/main.c clones of  stop are:
	raster/r.carve/vect.c  open_new_vect
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
