[GRASS-QA] GRASS QA: markus | ./grass6/general/g.transform/main.c
|no clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:10 EDT 2006
Hello markus,
ANALYSIS
general/g.transform/main.c functions
update_max (Begins at: 56 Ends at: 63)
Complexity: | 2 | | OK |
ParamNBR: | 3 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
update_stats (Begins at: 65 Ends at: 71)
Complexity: | 1 | | OK |
ParamNBR: | 6 | * | |
CalledNBR: | 3 | | OK |
LOC: | 7 | | OK |
metrics are OK
diagonal (Begins at: 73 Ends at: 77)
ParamNBR: | 4 | | OK |
CalledNBR: | 1 | | OK |
LOC: | 5 | | OK |
metrics are OK
compute_transformation (Begins at: 79 Ends at: 163)
Complexity: | 22 | * | |
ParamNBR: | 1 | | OK |
CalledNBR: | 33 | * | |
LOC: | 85 | | OK |
metrics are OK
do_max (Begins at: 165 Ends at: 168)
ParamNBR: | 2 | | OK |
LOC: | 4 | | OK |
metrics are OK
do_stats (Begins at: 170 Ends at: 177)
CalledNBR: | 5 | | OK |
LOC: | 8 | | OK |
metrics are OK
analyze (Begins at: 179 Ends at: 195)
Complexity: | 6 | | OK |
CalledNBR: | 7 | | OK |
LOC: | 17 | | OK |
metrics are OK
parse_format (Begins at: 197 Ends at: 224)
Complexity: | 10 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 28 | | OK |
metrics are OK
main (Begins at: 226 Ends at: 284)
CalledNBR: | 19 | | OK |
LOC: | 59 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
