[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.hull/main.c |no
clones | 0 monsters | 0 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:24 EDT 2006
Hello markus,
ANALYSIS
vector/v.hull/main.c functions
rightTurn (Begins at: 37 Ends at: 44)
Complexity: | 1 | | OK |
ParamNBR: | 4 | | OK |
CalledNBR: | 0 | | OK |
LOC: | 8 | | OK |
metrics are OK
cmpPoints (Begins at: 47 Ends at: 57)
Complexity: | 3 | | OK |
ParamNBR: | 2 | | OK |
LOC: | 11 | | OK |
metrics are OK
convexHull (Begins at: 60 Ends at: 122)
ParamNBR: | 3 | | OK |
CalledNBR: | 6 | | OK |
LOC: | 63 | | OK |
metrics are OK
loadSiteCoordinates (Begins at: 127 Ends at: 153)
Complexity: | 6 | | OK |
LOC: | 27 | | OK |
metrics are OK
outputHull (Begins at: 161 Ends at: 203)
CalledNBR: | 13 | | OK |
LOC: | 43 | | OK |
metrics are OK
main (Begins at: 207 Ends at: 287)
Complexity: | 7 | | OK |
CalledNBR: | 24 | | OK |
LOC: | 81 | | OK |
metrics are OK
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
