[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.to.points/main.c |no clones | 1 monsters | 2 warnings
Wed Aug 23 07:40:28 EDT 2006
Hello markus,
ANALYSIS
vector/v.to.points/main.c functions
write_point (Begins at: 32 Ends at: 58)
Complexity:   |       3 |       |      OK |
ParamNBR:     |       7 |    ** | Warning |
CalledNBR:    |      14 |       |      OK |
LOC:          |      27 |       |      OK |
at least 1 values are close to an outlier please consider revising code
write_line (Begins at: 60 Ends at: 134)
Complexity:   |       7 |       |      OK |
CalledNBR:    |      10 |       |      OK |
LOC:          |      75 |       |      OK |
main (Begins at: 136 Ends at: 328)
Complexity:   |      16 |     * |         |
CalledNBR:    |      89 |   *** | MONSTER |
LOC:          |     193 |    ** | Warning |
1 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
