[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.vol.rst/main.c |no clones | 3 monsters | 0 warnings
Wed Aug 23 07:40:28 EDT 2006
Hello markus,
ANALYSIS
vector/v.vol.rst/main.c functions
main (Begins at: 158 Ends at: 793)
Complexity:   |      86 |   *** | MONSTER |
CalledNBR:    |     255 |   *** | MONSTER |
LOC:          |     636 |   *** | MONSTER |
3 metric are OUT OF RANGE!
Clone analysis:
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
