[GRASS-QA] GRASS QA: markus | ./grass6/imagery/i.points/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c )| 0 monsters | 1 warnings
Wed Aug 23 07:40:12 EDT 2006
Hello markus,
ANALYSIS
imagery/i.points/main.c functions
main (Begins at: 21 Ends at: 146)
Complexity:   |      11 |       |      OK |
CalledNBR:    |      58 |    ** | Warning |
LOC:          |     126 |     * |         |
at least 1 values are close to an outlier please consider revising code
quit (Begins at: 148 Ends at: 171)
Complexity:   |       2 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      14 |       |      OK |
LOC:          |      24 |       |      OK |
metrics are OK
error (Begins at: 173 Ends at: 198)
Complexity:   |       3 |       |      OK |
CalledNBR:    |      16 |       |      OK |
LOC:          |      26 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  quit
In imagery/i.points/main.c clones of  quit are:
	imagery/i.vpoints/main.c  quit
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
