[GRASS-QA] GRASS QA: markus | ./grass6/vector/v.surf.rst/main.c |1 clones ( main.c main.c main.c main.c main.c main.c main.c main.c parser.c main.c main.c main.c main.c main.c main.c main.c main.c null.c main.c main.c main.c main.c main.c main.c main.c main.c main.c main.c main.c )| 3 monsters | 0 warnings
Wed Aug 23 07:40:28 EDT 2006
Hello markus,
ANALYSIS
vector/v.surf.rst/main.c functions
main (Begins at: 127 Ends at: 790)
Complexity:   |      90 |   *** | MONSTER |
CalledNBR:    |     262 |   *** | MONSTER |
LOC:          |     664 |   *** | MONSTER |
3 metric are OUT OF RANGE!
print_tree (Begins at: 794 Ends at: 832)
Complexity:   |       5 |       |      OK |
ParamNBR:     |       4 |       |      OK |
CalledNBR:    |       8 |       |      OK |
LOC:          |      39 |       |      OK |
metrics are OK
clean_fatal_error (Begins at: 836 Ends at: 863)
Complexity:   |       7 |       |      OK |
ParamNBR:     |       1 |       |      OK |
CalledNBR:    |      13 |       |      OK |
LOC:          |      28 |       |      OK |
metrics are OK
Clone analysis:
This file has 1 potentially cloned functions:
  clean_fatal_error
In vector/v.surf.rst/main.c clones of  clean_fatal_error are:
	raster/r.resamp.rst/main.c  clean_fatal_error
Threshold GRASS6 key metrics values at 2006-08-23 are:
                           | quartile  | limit   |
Complexity (Cyclo):      5 |        25 |      36 |
CalledNBR:               9 |        55 |      80 |
LOC:                    39 |       179 |     251 |
 LOC: Lines Of Code
Message interpretation:
 OK : Nothing to say at all
Brought to you by:
