[GRASS-QA] GRASS QA: markus |
./grass6/vector/v.lrs/v.lrs.where/main.c |no clones | 0
monsters | 1 warnings
grass-qa at proxy.soccerlab.polymtl.ca
Wed Aug 23 07:40:25 EDT 2006
Hello markus,
ANALYSIS
vector/v.lrs/v.lrs.where/main.c functions
main (Begins at: 35 Ends at: 197)
Complexity: | 14 | | OK |
ParamNBR: | 2 | | OK |
CalledNBR: | 58 | ** | Warning |
LOC: | 163 | * | |
at least 1 values are close to an outlier please consider revising code
Clone analysis:
This file does not contain cloned functions
Threshold GRASS6 key metrics values at 2006-08-23 are:
median | upper | outlier |
| quartile | limit |
Complexity (Cyclo): 5 | 25 | 36 |
ParamNBR: 2 | 6 | 8 |
CalledNBR: 9 | 55 | 80 |
LOC: 39 | 179 | 251 |
LOC: Lines Of Code
Message interpretation:
OK : Nothing to say at all
* : above 75 % of value warning
Brought to you by:
